M101a2 wheel bearing seal
uglysteve
Arizona
I'm not sure. I was waiting until I had parts to take it apart. Thanks for the help, I did not see that post when I did a search. I will order some seals.
[thumbzup]
blybrook
Fairbanks, AK
Napa has them for about $23 a piece. I just replaced mine when I replaced the parking brake cables.
EDIT - It is NAPA part number 22532 (found the receipt over lunch in the truck).
uglysteve
Arizona
Thanks for the help. I ordered some from etrailer.com for $3.99 a pair + $4.99 shippping. If they don't fit, I will go to Napa.
blybrook
Fairbanks, AK
I only went to napa so that I could get the trailer back up and going the same day. Plus most companies don't like to ship to AK, as they claim it's not continental US; so they give us international shipping. I have yet to deal with e-trailer, may have to give them a try in the future.
sigo
Lieutenant Colonel
374
Leavenworth, KS
blybrook,
Did you get a M101 recently from the DRMO here in Fairbanks? I am pending an EUC to pick mine up and was curious to know if yours needed new bearings or seals immediately? I know these were recently pulled from service here at FT Wainwright but most of them had not seen much use or maintenance in quite awhile.
I imagine it'd probably be wise to go ahead and plan on replacement, but if I can put it off I probably will. Too many other projects and all...
blybrook
Fairbanks, AK
blybrook,
Where did you find the brake cables? Were they a Napa part also?
THX
Kurt
Kurt,
No, I ordered them from Saturn Surplus per the part number that is listed in the TM. They turned out to be too long, so I had to modify how they mounted back to the frame at the handle side to prevent modifying the cable itself. I'll get a couple photos of that change in the near future. My modifications were essentially a new bolt mounted a few inches away from stock location and a spacer to hold the wire centered on the pulley back at the original mounting point.
Bill
Tymkpr
Norman, OK
I see the 10-36 is the bearing seal... OK
Now what would be the correct size hub bearing for the A2?
Picking up my A2 from Hooks later this month. Would like to have a couple in tool chest ready if I need to rebuild them before returning home 5 hours later.
Tymkpr
Norman, OK
Dang it.... I just need to look deeper. I found the correct thread that help me on the bearing info sorry to have to ask the question again.
