M101A2 Wheel Cylinder Bore Size?
rosco
Delta Junction, Alaska
What is the bore size, of the wheel cylinder, of the M101A2 series trailers? Was trying to verify the specs. I think its 1 1/8". Right & left as: BP 17-020, & BP 17-030. Hoping that someone could verify this, so I can get the parts coming.
The Master cylinder is 1" bore. Threaded end is 1/2"x 20TPI, hole spacing is 3.44". I forgot to verify the bore length, but think its about 4.25". If you buy this as a Master cylinder for one of the many industrial forklifts, it will cost about a third as much as when purchased from a trailer supply.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Gringeltaube has complete backing plates with all the brake components NEW for not much money. Might want to send him a PM.
rosco
Part Number
Thanks Gimp
The part number for the surge brake master cylinder on a M101A2 & 3 is: Clark 313200.
