M101a2 wheel- what valve stem?
TITANBOW
51
13
Longmont
Ok stupid question. I picked up a nice old 8 lug 16” Chevy steel wheel for a spare. It didn’t come with a valve stem. Can I just use the cheap rubber TR425 valve stems they sell at Autozone and the like? Or do these wheels require a special valve stem?
Jeepadict
655
Round Mountain, NV
Standard sizing "should" play. There's a marginal difference with rubber stems depending on the pressure you'll run. Discount will throw one in it for ya.
Sent from my SM-G970U using Tapatalk
juanprado
2,885
Metairie/La (N'awlins)
It can use a standard rubber stem but mine needed the bigger diameter not the regular auromotive one. Used on older 3/4 & 1 ton
Tr425 is the correct bigger diameter.
