M101A2 Wiring Question
665
Madison Alabama
I am switching out my trailer lights from civilian lights back to the military setup. I have the light mounted and plugged in. I am at the point of plugging the Intervehicular Cable with the Chassis Wiring Harness. I have plugged the wires in like below.
22-460 --> 22-460
23 --> 23
21 --> 21
24-483 --> 24-483
24-461 --> 24-461
24-484 --> 24-484
90A --> bolted to the inside of the drawbar.
I'm trying to figure out where plug 37 connects to. The wiring diagram shows it connecting to 37. I don't see a 37 coming from the back of the trailer. I tried to find this wire in the TM but can't seem to pin point this one. I also tried searching but got posts about going from military to civilian.
1,191
In the list of military wire numbers, 37 is listed as "Outlet Socket".
FMJ
37
Las Cruces, NM
Is this "list of military wire numbers" universal to all vehicles/trailers?
This is a very timely thread as I need to add a license plate light to my 101
1,824
37 is not used. If you goto the porch plug on a semi trailer, this number will have power all the time. Carry on without it.
665
Madison Alabama
I got the trailer lights wired up and have a small problem. The left and right turn signals work, the brake lights work and the running lights work. The problem I have is if the running lights are on or the brake light is on and I turn a turn signal on both the left and right lights blink. I have checked the ground and the connections. Anyone seen anything like this?
1,824
Odds are very good that you still have a ground issue. Bothbolt in each tail light nead clean grounds. Paint piercing washer work best if you have them.
glassk
Hampton, GA
Also the grounding straps inside the lights may not make contact with the housing or could be broken,... the plates are on rubber so the sockets are grounded with straps
