RLH
- 0
- 1
- PalmBeach, Fl.
Is the outside dimension of M101a3 from tire to tire larger than 72" inches?
Thanks for help..
Thanks for help..
Car hauler type or one with the little sides? I have put one (A1) catawampus on mine or they could turn it over and you carry it that way but you'll need a way to flip it back over when you get home. Waynedual axle trailer
I just doublechecked the TM and it does say bed width and track width is 81.5"I think the overall height is 81 to 83 inches, but the width from tire to tire is 72 to 73.5 inches. Looking at the data plate and TM online....
thanks for the info never knew there was a tech section
It would great to measure your M101a3 and see what I am up against.RLH, noticed you are in Palm Beach. Need to borrow a pintle hitch? Also, if they load it on top of your trailer, I can unload it for you. I'm out in the Acreage! You are also welcome to put a measuring stick to mine if you need to.
This is assuming 3 things!Wench the 101a3 up onto you car trailer as far as you can, lower the front landing gear, then jack the trailer up and set the axle on a set of jack stands.
Use a chain binder and crank the binder until the trailer won't move.
1). Never assume.This is assuming 3 things!
1) He has a wench
2) She is willing to ride to JAX with him and
3) She is strong enough to pull a trailer.
Nothing more than my trailer to measure and actually see, a spare to take with him, my crane to unload it if he brings it back on his trailer and a bit of humor.
3). Without spelling errors I take it you have nothing to add about loading his new 101a3 onto the smaller trailer? I read your post about loaning him you pintle hitch which is a very admirable thing to do.
