OK so iv been playing with the truck, i took the tank vent line off the upper fill neck. Then plugged the neck and turned around the vent hose over the tank and added a breather element. I did this after the tank gasped for air at the pump, so i figured a venting problem was the culprit after all. It did help with the shaking a bit. One day my dad told me about a 22R yota he had when i was little that had a vapor lock problem from ****. No one could figure out what was causing it but leaving the gas cap loss solved the problem...how? no one knows? So after that i returned the vent system to factory and just gently snug on the gas cap so it stays. Also iv learned that the old style fuel gauges in these trucks really are hit and miss. So if the truck has a 20G capacity at least one or two gallons arnt accounted for on the gauge so when you do hit "E" you can still go a little farther if need be. So if im at a quarter tank it should take about thirteen gallons to hit full, NOPE takes ten....don't know why i guess the truck just has character. Probably just an old miss adjusted arm or rheostat or what ever is in there.
Also I found a few injectors going out. Used a stethoscope to listen for the pops and a couple barely puffed. So thats what i did all week end, injectors came with no rings and had to order those. A few return lines died during surgery and no one sells that diameter line by the foot in my area. So i wasted a day waiting for auto zone BS kit to arrive. I'm glad i did it though i pushed the truck a few days with a rough uneven idle but she is running like a top and a very even clatter. Even got rid of some of the vibrating and i got a few horses back. But I do have to ask does any one know why i hear a long swish as i accelerate all most like listening to the spray of the injectors. Im not that familiar with the sound of indirect injectors. I looked through the TM's but theirs no mention of it. Next week when i refuel ill see if the truck still shudders or not. I'm off to ask Google about the swishing sound.
