M1028 steering knuckle
islandguydon
783
Michigan
There is a 4 bolt connection knuckle bolted to the top of the wheel and attached to the steering box. The bolt pattern is 4 # 8 bolts 2 facing the tire and 2 facing the motor. The 2 facing the motor was gone and only 1 facing the tire was attached, the other one snapped off.
Needless to say I went to drive and the wheel turned but the truck went straight. Had to flat bed to shop for repair. According to the cameras Medina,s at fault here. This is going to be a ride to remember. BTW Medina is a gremlin.
Anyone had a steering knuckle simply fall apart..? ERIE feeling...!
islandguydon
783
Michigan
Sounds like it to me. Someone forgot to fully seat the studs and or torque the nuts!
I was told the motor pool 25 years ago was full of young soldiers, enough said. Yes the king pin assembly, top 4 bolts # 8-6.25" fine thread.
I shipped the truck to the dealer and 3 hours had the problem fixed, re tap & die. + 4 new Bolts. $210.00 back to factory spec, ouch.
The lesson here is to fully check your equipment, all nuts and bolts.
Don
