m1028 Trailer Wiring help
hovenga67
Evansdale/IA
Are u willing to lose your military trailer plug in the rear? I can make one I have done it on all mine. If you want to keep the current plug it is still do able but takes a little more work.
hovenga67
Evansdale/IA
Are the plugs for the military plugs still behind the bumper. There should be 2 connectors. They are called weather pack connectors. That is what I make my adapter tie into for the taillight signal.
Skinny
487
Portsmouth, NH
I've got one that has that style along with a flat 4/5 underneath it. Nothing plug and play though, you will have to tap into the military harness or the factory tail lights. If you do find something plug and play, post it up. I doubt it because of the age of the vehicle. The combination plug set up is trick because you know that you will have the correct harness every time regardless of what you hook to.
hannaganscr
Bode Iowa
I am not looking for an adapter I am looking for someone to MAKE me a plug in harness that I can just plug into my existing truck wiring harness on the truck. The original military trailer plug is gone but the tail light harness is untouched. Thanks again....
