M1028 Transmission grind when put into park
Zero_cool
Virginia,Minnesota
Hey guys, I have a 1987 M1028 with 20k miles the tranny and T/C work good.
I just noticed that when I put it in (P) that it make a little rattle / grinding noise.
Its not a continuous noise just last for mabey 1 - 2 seconds then stops.
Any ideas what would cause this? And how to fix it?
Thanks in advance, Dano
dependable
187
Tisbury, Massachusetts
Sometimes this happens if in 4wd esp low range, if you put in park and there are tensions between axels, with locker in the back and limated slip in front. If level and soft ground, should not happen. I would not worry about it. If this is happening in 2wd, you may have other problems. Perhaps check tranny and transfer case linkages, ie make sure park position on transmission matches position on steering column with no tension in linkage. This would happen if linkage got bent off road or with fork lift.
papercu
31
Baxley, Ga.
From the papercu -10 "
1. Turn ignition key to off position
2. Shift transmission gearshift lever to “P”( Park)
3. Turn key to lock position
4. Remove key and place in shoe
Wayne 2cents
Zero_cool
Virginia,Minnesota
Dependable, it does do it in 2 WD and Im on level ground ( black top ) I will check the linkage tomorrow morning. Is this something that could cause more damage if i dont get it fixed right away? What is going on inside that it would make the rattle / grinding noise? ( so i can better understand the problem ) Thanks For the Help I really appreaciate it.
Dano
401-J10
asheville, nc
I actually have the same exact problem in my turbo 400 in my jeep truck and I just rebuilt it, although it did it before too. I talked to a guy that really knows these transmissions and he said it pretty much has to be that the linkage is adjusted wrong or a spring in the transmission that actually puts it in park is weak(sorry i can't remember any of the technical terms right now). I think hes right cause with mine if i shift it quickly and really far over it doesn't do it. But fwiw I don't think it actually hurts anything in the trans. I think its already been said but i would make sure the linkage is allowing it to go far enough into park. Hope this helps.
Zero_cool
Virginia,Minnesota
401-j10 Thanks buddy, I checked the linkage like you and dependable said, from what i can see its not binding or bend, But If I shift it really fast like you said you did, it doesnt rattle / grind so I dont think Im gonna worry about it anymore...Thanks alot guys
