M1028a2 front hub rehab
319cssb
221
Easley SC
Good morning everyone.
is there a two piece seal for the front axle of the dually? I am going to replace the wheel bearing and was wondering if the bearings are special? Autozone got a few to pick from. Anything i should look out for?
cucvrus
10,505
Jonestown Pennsylvania
Describe 2 piece seal. I think it is just a 1984 dually front grease seal. Nothing special that I am aware of. I only ever had 1 dually CUCV and I bought standard parts for it at Autozone, NAPA, or Mom and Pop auto parts. Same as civilian. I bought National seals. I hope that helps. Get the spindle seals and the dust seals that are in behind the spindle. Make sure you clean and grease the often neglected spindle bearings. Good Luck.
319cssb
221
Easley SC
I must have read something and mixed it up with a rear axle seal. I think someone mentioned a two component seal that wouldn't leak easily.
319cssb
221
Easley SC
What a total and utter pain, I couldn't get the small surclip on the axle. Ill drive her a few miles and see if i can then tighten the inner and outer lock nuts some more. There is a smidge missing dor the surclip to go in its grove. The larger surclip went in without problem
TGP (IL)
36
Metro East IL
The inner and outer bearing nuts have nothing to do with the inner axle not getting the clip on.
Those nuts Must be adjusted correctly for proper bearing pre-load.
Take a small pry bar, reach around the backing plate and gently pry the axle U joint toward the Hub.
The axle slides inward while your working on it and you need to bring it back out to install the clip.
You need a manual.
Tom
319cssb
221
Easley SC
Yes, thinking of it what you say makes sense. I was in the heat and a bit dehydrated. I'll do some prying tomorrow.
PS which TM has the procedure? I looked in the -20 and it doesn't talk in much detail of how the job is supposed to be performed
319cssb
221
Easley SC
Did as suggested and pushed carefully out on the axle and the snap ring went right in. One problem down 99 more to go.
Don't work on your truck when dehydrated!!!
