- 599
- 699
- 93
- Okinawa, Japan
The truck is a 1985 model. 586 must be for something else.41-9 stamped in ring gear means 41 teeth on ring gear and 9 teeth on pinion gear. 41 divided by 9 equals 4.56 ratio. 586 is probably May 1986.
Anything is possible but I'm not sure what the 586 stamped into the front differential ring gear has to do with the rearend.Might have a 1986 rearend in it!
The tags were there. The truck was manufactured in 10/84. The newest tire on it was manufactured in 1988. The odometer read 36,400 miles and from everything I've inspected I believe it to be accurate. Speedometer works fine as well.Most of these trucks went through a referb at some point. Rebuilds depended on what was wrong. You can expect to find many replaced parts. Also the odometer is most likely not the true mileage. I would bet 586 would mean May of 1986. The rebuild tag on one of the diff cover bolts was most likely lost/removed many oil changes ago.
