brianrbull
- 9
- 18
- Casnovia Michigan
I am starting this Thread to Document my Build from start to finish...
Phase 1 Planning and Discussion:
My intent is to build an Expedition Camper. I am planning on using the frame and axle from a M105a2 Trailer, an S250G Shelter, and a MEP-002ask .
I will be adding an onboard fuel tank of some sort , and an Underbody Style Spare Tire Carrier from an M1061 Laundry Trailer.
My Prime Mover needs to be my M1031 Contact Truck.
The intentions are to install the Shelter beginning center line of the axle, mounting the Generator sideways across the Trailer Frame. Spare Tire will be mounted at the rear most part of the frame.
I will need to
1: Flip the Lunette, Install M1061 Trailer rims with Load Range E 16.5 Tires Hopefully this will lower the trailer enough to comfortably pull with the CUCV.
2: Remove the Trailer Bed
3: Extend the rear of the trailer frame to accommodate the Shelter (102") Looks like centerline of the axle to end of frame is 50" so I will need to extend the frame an additional 52' Probably will do the extention with a combination of welding and plating as I intend to install a pintle hitch on the rear of the trailer.
4: I am going to make a deck of hardwood 2x6 to set the shelter on and then use cables and turnbuckles to hold it down.
5: The Brakes are going to need to operate as this trailer is going to be upwards of 4000# when finished. Electrical operated seems to be my best bet here.
6: The Generator will be mounted across the frame , Just forward of the tires. I am hoping the shelter will counterbalance the generator enough....
Am I crazy? Please pick me apart. I want to do this right as it will be my camper for a 6 month "Walkabout" once come home from the Sand Box (I am a Deployed Contractor)
I will need to
