M1030B1 key lock question
Fig
Oklahoma
I have a 2000 M1030B1 that seems to have a key I cannot remove. The key turns freely from "on" to "off" but will not turn to "lock", the key can be pushed down in the "off" position but only about a 1/16th inch, the fork locking mechanism doesnt make any sounds and is possibly stuck
Should I be able to remove the key in the "off" position? Or does it need to be locked for the key to be removed?
Fig
Oklahoma
Update, nevermind found out the key is in there permanently
diesel fan
herrin, il
My key was glued into the cylinder. I replaced it with a regular KLR key and cylinder. You need only the ignition key/cylinder. Not the whole kit, ignition, gas cap and helmet lock cylinder.
