M1031 CUCV lost all power to fues box
Brent.Cain
Canal Winchester, OHIO
Good morning fellow SS members. Looking for a little help this morning, I stared my truck and drove 30 miles. I parked and shut the truck down and when into a building for maybe 5 min. When i came back out the when to the start the truck it started to engauge to start and then it just flat lined so i know i blew a fuse or somthing but i have no power to the fues box can some body help me out there
PS. the truck has 44,000 miles no hack job wireing all stock
K9Vic
Fort Worth, TX
Did you check the fusible link from the terminal block on t he firewall next to the GP solenoid that runs from the 12v side of the second battery?
Brent.Cain
Well I got good an bad news good news is the truck is running again bad news is idk what happen to fix it we was pulling the truck back words when everything started working and fired up so who knows how long until is happens again
1,178
Pull and clean all of your battery connections.
rickf
1,638
Pemberton, N.J.
Also take out and put back in every fuse in the in the fuse panel. They get corrosion on them and do just what you experienced. You do not have to replace them with new ones, just remove and put back to clean up the connection.
Rick
ballencd
78
Columbus, NC
Try to tighten the fuse block thru bolt
There is a bolt that holds the two halves of the fuse block together....like a clam shell... if you will. I believe the bolt is on the engine side of the block but it has been a long time since I had trouble with mine and I have slept since then. It is right in the middle and pulls the inside and the outside together and when it does it connects the two parts. I found power on the wires going into the fire wall on the inside but none on the other side of the firewall under the dash on mine and tightening the bolt fixed it. Good luck.
cpf240
Free in Northern Idaho
While you are at it, disconnect the batteries and then disconnect this harness from the engine side of the firewall. Clean the heck out of the connectors with electrical contact cleaner and a toothbrush. Then reassemble with a healthy does of dielectric grease!
