M1031 Governor Control
gwag
Lemmon SD
If I'm wrong someone please correct me but I believe it takes 1800 rpm to maintain 60 hertz. I'm guessing that is actual armature rpms.
This would be a good question in the Hear Ye Hear Ye thread and help to get it back on the tech track at the same time I guarantee some one following it will know.
b4thundr
LaFayette, NY
Hey I know the PTO shaft RPM I don't know the engine RPM, sounds about right though. the farm service truck we were using the wood stick between the gas pedal and the seat method, boy that worked good:roll: not! I needed to know the shaft PRM to program the new controller
Doug
NDT
6,065
Camp Wood/LC, TX
b4thundr, you will know the generator is turning at the correct RPM when the hertz gauge indicates 60.
south101
Houston, TX
Did you try to sensing off of the engine tach signal? Or, did you just decide to add a sensor to the pto shaft. Also, is there any fault sensing with your setup?
b4thundr
LaFayette, NY
At the farm we have a tach that reads shaft rpm's on anything! if it spins and its a shaft this tach will read it works great! The controller looks at the shaft RPM not the engine RPM. And yes this controller has a fail safe if the shaft goes over a certain rpm it kills the actuator and returns it to an idle.
south101
Houston, TX
You might want to add a reference to the engine tach as well. PTO shaft failure could result in a situation where pto rpm is within spec but engine rpm is driven up beyond a safe operating range. Else, the implementing a rev limiter might be a good idea. Perhaps a scenario might be where the pto is disengaged and the control box is activated. Not sure if this is an issue but a possibility.
b4thundr
LaFayette, NY
Thought about that, there is nothing on the motor to get a signal from currently, the stock set up does not do this ether. guess the government thought the truck motors were expendable too!! LOL as long as the shaft get maintained properly there should not be any issues.
south101
Houston, TX
Is there anyway someone could disengage the PTO with the control box still trying to correct by bringing the engine rpm up? You might reconsider and have your failsafe work based on sensed engine rpm. That's where the most damage could occur, I'm guessing. You could add your sensor to the harmonic balancer.
