Jim kinser
- 0
- 0
- philadelphia
Hello all. I belong to a search and rescue team that has a M 1031 that we use as a power and light unit during ms sing person searches.
Recently we were trying to use the PTO driven Generator on the truck and noticed that the throttle governor would not Rev the motors RPMs high enough to maintain 110 volts.
We did follow the procedure to the letter as far as engaging the Generator.
This truck is equipped with a toggle switch on the dash, next to the light that indicates that the PTO is engaged, when we would flip the switch the trucks idle would increase about 200 RPM, and only dimly light some 500 watt halogen lights.
Has anyone encounter this problem before? Where the throttle governor will not increase the engine RPMs.
What can be done to fix it? And if the governor needs to be replaced, where can I find a new one for this type of truck? I am trying to keep all parts original and avoiding civilian parts.
Thank you.
Thank you.
