m1038 7k -87 brake questions
Rsh_86
Norway
hello from norway!
Ii have tried the search function but could not fint a clear answer.
to the question .. does the 7k and 10k trucks use the same brake parts like rotor , pads and caliper ? if so that means i can use brake parts from like a 92 hummer h1 ?
Action
1,552
East Tennessee
The first humvees had the same calipers on the rear as it did in the front. The e-brake was on the propshaft, just in front of rear diff.
They were upgraded to the larger rear caliper with e-brake.
The H1 will work.
