kahlem01
- 0
- 0
- royersford pa
Hi- this is my first post, could not find the info i need but am sure it is actually here somewhere. I have a 1984 mkt-85 that I am planning on using as a multipurpose camping base. I need to lighten the chassis which Is currently pulled out. I have removed all the brake stuff and am in process of removing the brake hubs from the axles. I wanted to replace the axle with a 3500# but not sure if i can simply trim weight by removing leafs and maybe replacing the tires/wheels with lighter civilian bolt on. Some more notes: the trailer is empty, no kitchen/no canvas just a gas bbq right now and will be used for camping and tailgating. The pintle is removed and a great job of an adjustable ball hitch was welded on. I am towing with an astro van , tows fine empty but i need to lose weight so i can add some gear. Any help would be greatly appreciated. If its already posted somewhere, just point me in the right direction. 3-3/8ths wheel bearing socket, who has that in a home toolbox?
thanks
mike
thanks
mike
