CGarbee
- 552
- 113
- Raleigh, NC
Guys,
I need the front landing leg for a M104 1.5 ton trailer. Leg is NOT the same as that used on the similar M105 trailer as it sits beneath the frame rail when in the raised position in order for the front tailgate to lay flat... The M105 legs when in the upright position ride above the frame and will interfere with the tailgate and thus can't be used...
I'll be heading out to Tulsa, OK next month (June), so picking one up along the way (I40 routing) would work if I can't find one closer to home...
My trailer is in need of some cosmetic work and a new front landing leg since somebody removed the original unit, but it sure does tow nicely behind my deuce... It's just a real pain to pick up the front end when its time to hitch it up...
Thanks,
Thanks,
