m1045a2 only two gears, limp mode?
2mas-
Norway, Kr.Sand
Hi,
I think my Hmmwv m1045a2 went into limp mode. It happend after the authorities had them at the brake rollers and triend the brakes. Noticed it will only shift to second gear. Tried Drive and Overdrive no difference
Any tips? Do you know how the transmission and transfer case should be set when the hmmwv is tested at the brake rollers? It was now in Overdrive and H on transfer case
The light on the transmission in the console lights up when put on the ignition but goes out after I start it, it has been like that since i got it, but I think that is how it should be?
The Oil level on the transmission is normal
Thank you
From 2mas-
TOBASH
3,363
Brooklyn, NY
There is nothing less fun than using a technical manual instead of months of trial and error.
Seriously, TM's are the way to go.
Remember, DISCONNECT THE BATTERIES prior to doing any electrical work!
2mas-
Norway, Kr.Sand
Thank you very much for answers
Can I just put a clip in A and E on the J2 port on the transmission box and turn the ignition on and the fault code will flash? Is in nescessary to plug out the glowplug box first?
From Thomas
NDT
6,279
Camp Wood/LC, TX
Order a new part and cross fingers? If I were here I would suggest taking it to a transmission shop, but over there it will be very difficult to find GM Hydramatic expert.
86sa
miami fl
I took a H1 to several trans shops none had proper test equipment such as scan tool tech 2. I purchased a tech 2 and checked trans sensors brake sw tiss toss tps torque converter. All was well except tps. Unless trans shop has tech 2 and proper adapter run don't walk away. aammccoo wanted to replace trans after poking around for 4 hours and not finding anything definitive at $3600. TPS is 50.00.
86sa
miami fl
Online auction site. Was 700.00 not a Chinese knock off. I needed it for multiple vehicles. Finding a shop with one would be the best solution even if you had to buy the adapter for humvee use. So much info is displayed.
