M105 a2
Rthomas
Jena,La
What do you need to tow a M105 A2 ? I am looking at some to flip. I live around a lot of oilfield companies. do you think they will sell?
maplehillfrm
binghamton ny
hey welcome, empty the weigh 2650 lbs more or less,, so towing them home from the site you can use probably a 1/2 ton, I prefer a 3/4 ton, but thats me, remember they will not have brakes with a civvy truck,, the brakes are air over hydraulics , you can tow t hem with out air but you wont have any brakes to them untill you hook them to a vehicle with air connectors,,
They were built for the 2 1/2 ton truck to pull, so that is really what you are going to need to haul it around safely with any load on it, a 1 ton would probably be ok, but again you fall into NO brakes,,
they sit higher than a normal trailer on your pickup , so you need to flip the lunnette,a nd have a raised hitch to get it somewhat level,,
They are buily rugged as all get out and will haul alot,, I use mine around the farma nd hook them to the tractor to pull around,,
as far as flipping them, {you dont mean rolling them over right??:roll::cookoo: hahah]
it will be hit and miss , if you find someone that needs one great otherwise you could sit on them for a while, I have several I want to sell, some sell, some dont,, right place at the right time,, a title will help it sell a little faster I think, you need to apply for a sf97,, 60 bucks thru gl then register it,, so it will cost a bit,,
there are always trailers on ebay,, some sell most sit,, but area and demand will play a roll in it.. try to have them sold prior to pickeing them up,, or pay scrap price for them so you can at least cut them up and break even maybe,,
you can get 3 on a 25' gooseneck to get them home,with a bit of work,, good luck, pat
roscoe
Spencerville, Indiana
They are neat little trailers, however most people aren't going to have the correct setup to pull one without modifications on the electric, height and braking.
Trailboss
137
Norwood LA
I've lived and worked in the oil and gas industry from drilling to refining for 30+ years, and I haven't seen many small trailers used. Don't plan your retirement on flipping M105s to oilfield companies. Now, the M871 trailers would be more useful in the industry.
That said, if you find a market let me know since I have about 1/2 dozen of the M105s :lol:
Rthomas
Jena,La
I had a cousin get a cement mixer from the bridge that they are building in St. Francisville. All it was was the 10 yard drum and he sold it
