Duece Man 35a2
- 8
- 3
- Ft Myers FL.
This is my first post, so here you go. I have a M105 trailer and I believe it is the newer style brake system. Air goes into the trailer from rear of the truck, both sides, the service and the emergency lines. Goes thru the filters and into the air brake relay valve (2 sides) which is mounted to the air tank with a 1" nipple. There is a third line coming from the relay valve and goes to a diaphragm attached the master cyl. From the master cyl. to the wheel cyl. it's hydraulic (dot 5). Everything from truck to trailer is hooked up, air and electric. One side of the trailer on jack stand, tire spins freely. Truck gland valves closed both sides, trailer air tank empty. Open the service side only (drivers side) and step on the brake pedal. Go back to the trailer and the wheel will not rotate. Crawl under the trailer and empty the air tank/drain valve and the wheel spins again, air tank pressure let off. Close service side and open emergency side gland, wheel locks up. Air tank full again and must drain air again to release the wheel. Air relay valve seems to be doing nothing. Old valve and a new replacement are doing the same thing. The truck shop matched it up and they look the same. Could they still be different? What is the right part number? Going nuts!!!
