M105A2 on a 16' trailer?
M35A2-AZ
390
Tonopah, AZ
Hello, I have been trying to find the dimensions of an M105a2 trailer.
I am going to pick one up with some other things and I’m trying to see if it will all fit on my 16’
trailer.
What I need is the outside width dimension of the wheels and how long the 105 is from the ring to the back of the trailer and maybe from the front trailer jack to the back.
M35A2-AZ
390
Tonopah, AZ
3dAngus
101
Perry, Ga.
Also consider your 16' trailer tires location and how you load it. Your trailer is wider than mine at 72" but my side rails are removeable and I would leave them at home for what you are doing. Good luck. Sounds like fun!
11Echo
92
CT W. R.
trailer.
Length for one trailer on a 16 footer won't be a problem. You don't say how wide your trailer is. Here are 2 on a 20' trailer.
M35A2-AZ
390
Tonopah, AZ
11Echo, My 16' has a rail around it and the inside dimensions is 83" on the width.
Do you think the M105 will fit inside the rails?
Thanks!!
Unforgiven
Las Vegas, NV
88" outside tread to outside tread (including sidewall bulge)
94" outside fender well to outside fender well
Just measured it 2 mins ago for you on an M105A3.
The A2 trailers are slightly more narrow. But that'll give you an idea. Bring some lumber in case you have to set the M105 on top of the flatbed trailer's fender wells. You might have to remove one or both side rails.
KsM715
142
St George Ks
I just went outside and measured my M105A2 (its like 10 degrees out now) Mine measures 79.5" give or take, outside rubber to outside rubber. The wheel dish/hub/lugnuts stick out another 1.5"-2" either side but they should clear your side rails. These pics are when I picked up one of my trailers and some other stuff on a 16' trailer.
86m1028
17
Murphy TEXAS
I have an 18 ft trailer 83in wide, with rails & have put 2 m105s on it no problem.
I also carry 3 m101's at a time on it.
Hope this helps.
M35A2-AZ
390
Tonopah, AZ
Thanks guys for all the inputs!!!:beer:
Just have to wait a little bit for the EUC....then road trip!!!:driver:
