M105A2 Wheel Bearing Maintenance
Bobcat701
Autryville, NC
I am planning on repacking the wheel bearings on a M105a2trailer. The TM states to replace theOil Seal Hubs during the procedures. Anyleads on procuring 6 oil seal hubs would be greatly appreciated. I have three trailers that I need to service.
Barrman
1,685
Giddings, Texas
Pull them apart. Your seals probably are still good. If not, the TM has the part number and there will also be a part number on the seal itself once you have it in your hand. Between the two, I they are different, you should be ok.
