M105A3 bed for bobber... anyone
wehring
26
Angleton, TX
Has anyone used an M105A3 trailer bed for a bobbed conversion yet? I love how the rear lights are mounted. Don't know if the shallow fender wells will pose a problem or not...
Justin Wehring
979 997 3112
wehring
26
Angleton, TX
Thanks...
Do you have one? I would love to get my hands on one (even if it is a loaner) to better research this.
For starters I can use a measurement between the verticle pannels of the wheels wells. They are wider between the wheel wells than the A2s but I don't know how much. I need to see if they will clear the tires on the bobbers.
Thanks!
Justin
hoopsoft
Purcell, OK
uh save some for the rest of us now.. I wished you could train two of them together, not sure if it would be legal though, they do it with semi trailers.
wehring
26
Angleton, TX
Train
DO NOT TRAIN THE M105s!!!!!! I did this from AL and posted a caution thread on it. I have pulled many trailers in train config with no problems but the M105s are very dangerous! I bridled the two together to get home but I will never do it again.
Justin
979 997 3112
DUECE-COUPE
Scurry. Tx
i used a105a2 generator trailer. after you cut it down to what you want, you have a better bed than the a3. the a3 is only 34 inches wide and then you have the fenders sticking out the sides. the 105a2 gen trailer gives more options. the 105a3 is a rarer trailer and harder to get parts for. on the up side, the only part that is hard to obtain is the fender. every thing else is just plate steel and tubing.
asgtoolman
Florence SC
I am putting an M116a3 bed on mine, should have photos to post by the end of the week--I went with this bed because outside of fender to outside of fender on trailer bed exactly matches front fenders on cab. I went with this 8' bed because I wanted my truck as short as possible; even changed to a 15,000 pound electric winch which saved over a foot from a PTO operated winch
