M105A3 mods?
FJ4X4TRD
Corpus Christi,TX
I recently picked up a really nice, almost mint M105A3. Admittedly, it is a little more trailer than I need, but couldn't pass up the deal, and at the same time I'm holding out hope to mod it slightly to suit my needs.
Looking to:
mount smaller wheels/tires
remove some of the leaf springs(as I'll never need to load to capacity)
My goal is to lower the trailer, and perhaps reduce some of the weight in the process to make the trailer work for me.
I've got a Toyota FJ, with slight lift.
Thanks a million for advice/specs/tips on what is possible.
Rob-
:grin:
1,807
Bolster trailer tires and wheels should fit. They will lower it but are not much lighter. What you save in purchase price will be spent on dieting the trailer. Might consider flipping it and getting a 101 or 1101.
M813rc
3,052
Near Austin, Texas
What Recovery said.
There are not that many M105A3s out there, so someone is likely to want it unmodified; and even with your mods, it will be big for an FJ.
An M101A3 is about the right size for your Toyota (it's still pretty big!) has surge brakes and CUCV wheels on it. They are pretty readily available in TX.
An 1101/1102 (which are essentially the same trailer) is much lighter than the 105, though bulkier than an M101, and the bolt pattern for the wheels means easy swap for civvie type tires/wheels.
Just a thought.
Cheers
