M1070 55000 T Case won’t shift to low
JphOshkosh
Hartland, Wisconsin
Recently bought a m1070. Most all is good except. Transfer case won’t shift into low gear. Runs fine in high but shit lever won’t go into low. Any advice on a possible cause and fix would be greatly appreciated.
Also - any referrals to manuals and videos of removal and maintenance of an Oshkosh 55000 transfer case would help.
If I need replace - are there several models of 55000 cases? I have found several for sale but the only differences identified are a narrow or wide pattern. I assume the m1070 is a wide one but are there other distinctions?
Thanks much for any and all help.
monstermog
Billings, MT
Oh....well I have had the same issues at least I thought so at first. I was told to try moving fwd ...coasting and it went right in....the same for putting it back in high. Have you tried this methid?
simp5782
Feo, Fuerte y Formal
9,322
Mason, TN
The 55000 cases arent as plentiful as they once were years ago. Those who have them want a pretty penny.
Did you remove the cable at the transfer case shift rod and attempt to move the shaft with a prybar. Simply place a bolt thru the clevis end. You probably just have a shift cable with water in it and rusted it up.
55000a transfer case is normal in junkyards removed from old oshkosh snowplows
monstermog
Billings, MT
No I did not remove the cable. I just provided a small fwd movement and it shifted into low gear.
