M1078 bed blueprints
Dave the Forester
Astoria, OR
Anyone know where I can find blueprints or a CAD drawing of the bed on the M1078? I'm converting the original to a brush engine and I want to replace the original bed with an aluminum one so I can carry more water.
wheelspinner
1,518
North Carolina - FINALLY !
It is standard frame width. Something to note is you could probably also remove the riser channel. To do this you would need to notch up front for the trans/transfer case but since you are building yourself this would be easy. Make it fit your needs more than just mimicking what is already there. Just my thoughts.
