M1078 Daytime running lights
Duuks
Fort St John, BC, Canada
So where I live having daytime running lights is mandatory. Ignition turns on, daytime runners turn on automatically.
I was wondering if anyone has set this up for their m1078? I have a 1997 m1078.
simp5782
Feo, Fuerte y Formal
9,330
Mason, TN
Most of us all run with headlights for safety when operating anyway. Just make a habit of turning your 3 way switch on all the time
simp5782
9,330
Mason, TN
So you would need to basically just run a jumper from one light across to the other and then hook into an KOER fuse in the box would be the simplest. So you would need to take a test light and find which fuse location is suitable to tie in to and just run a wire
Andyrv6av8r
455
Spartanburg,SC
I put a keyed switch in mine running to a solenoid that kills battery power. I leave my light switch in the ON position so that as soon as you turn on the keyed switch to start the truck , lights are on.
coachgeo
3,404
North of Cincy OH
Something I've been considering is run a second power line off the alternator exciter wire to a solenoid. It in round about ways comes from an oil pressure switch on the engine. This solenoid would need to be wired to be what sends power to the light switch (that has been left on*). That way will only power lights when engine reaches certain level oil pressure.. Aka.. Engine is running. This way you do not have additional draw on batteries when starting engine. Starter needs all the juice. Cranking the starter with lacking battery power is a fast way to ruin a very expensive starter.
You could wire a second solenoid power source to the light switch if you want to Power the lights with engine off on occasion
*if they are extra picky you can add jump wires to back of switch so running lights always come on when this solenoid kicks over even if the light switch is NOT set to have them on
