Hello all,
I have looked through every thread having to do with the FMTV hydraulic system and have not been able to find anyone who has had the problem I am experiencing.
Some background info: I was a 91B in the army, but I worked on mostly FOSOV vehicles. Worked on LMTV's a bit when in garrison, but by no means am I an expert. The AOP and Hydraulic manifold were both rebuilt in 2021. I switched over to using AW-32 hydraulic oil, as it is more readily available to me, in 2022. Over the past few years, the system has worked as it should. It is also worth mentioning that the hydraulic system has been modified to operate a stage and a roof on the back of the truck. My company uses the truck as a marketing vehicle.
The problem: Last fall, while lowering the roof, the hand pump reservoir just exploded. I got a new hand pump (This one: Replacement LMTV/MTV/FMTV Manual Cab Pump (midwestmilitaryequipment.com) ) . It worked as it should for a while until yesterday when it exploded again.
My understanding is that oil will return to the hand pump until it hits a certain amount of pressure where it will then trigger a check valve in the manifold to return the rest of the oil to the AOP.
I am assuming that the check valve is not being triggered so the oil is building up pressure in the hand pump reservoir until it eventually gives in.
Has anyone ever dealt with this issue? Am I on the right track? Any insight?
Thanks in advance.
Thanks in advance.
