M1078 no crank blows fuse
AlaskanLMTV
Palmer, AK
Good morning from Alaska!
I've acquired a 2000 M1078A1, learning as I go... after completing the services, filters and all of the fluids since the Army drained everything, this machine pops the CB77 fuse every time I flip the power switch.
Fuse block and cover appear to match, the blown CB77 fuse that came with this machine was a 20a. I've swapped out all of the resettable fuses that failed with standard blade fuses. the fuse box cover says the CB77 should be a 10a. that had me a little concerned right away...
so far, we've isolated the starter relay, completely removed it and still pops the fuse. if I jump the relay, the starter engages and spins the motor but won't start since the Cat computer isnt on.
I've isolated the air heater grid, still pops the fuse. And we've isolated and bypassed the Pac Brake solenoid, still pops the fuse.
Next, I downloaded the manuals, but I'm running in to a wall... I think the TM manual I found is for an older unit, we went through the electrical steps til it calls for testing K24 relay. My LMTV doesn't have a K24 relay, unless there is another panel that I haven't found yet.
Any ideas?
Ronmar
8,142
Port angeles wa
Pull relay K11(alt excite) and K26(neutral start) and see if it still pops CB77. If it doesn't pop 77, re-install one relay at a time and see which one pops CB77...
need a direction to follow. My money is on K11 providing the short circuit path:)
Ronmar
8,142
Port angeles wa
My reason for betting on K11 being the path that causes the short, is that when K11 energizes with the ignition sw, it provided power from CB77 to the start switches. One of those switches is down on the passenger frame rail/out in the weather. If the wiring has been damaged or the sw has developed an internal short to ground, that could be a very likely source of the issue…
AlaskanLMTV
Palmer, AK
K11 removed did not correct the CB77 fuse popping. I went ahead and pulled every fuse and relay on the 24v side of the fuse block EXCEPT the CB77, flipped the master and immediately popped the fuse. Next, I reinstalled all of the fuses and relays in correct order, and started pulling connectors off of the back of the fuse block. The very far left hand connector disconnected, master on and didn't pop the fuse.
I think my next step is to identify all of the lay line numbers and track each circuit that they go to. Yay...........
AlaskanLMTV
Palmer, AK
Maybe shorted trans tcm. Behind passenger kick panel. 3 plugs just unplug them
Unplugged all three TCM connectors, no change. The transmission display comes alive when I put power to the system, displays vehicle is in Neutral. Some of the lights illuminate on the dash, the Transmission light comes on and quickly goes out. I'm thinking the transmission is talking, it appears to be at least electrically communicating. Wont know till I can get the engine to fire and then top off the remaining fluids, and then push a button and see what happens!!
Ronmar
8,142
Port angeles wa
Well never was much of a gambler:)
Ok, if K11 and K26 removed did not stop 77 from tripping, there are only a few other places that power goes, and all of them are in the drivers dash.
The alarm buzzer in the dash, which is controlled by grounds provided by the low air switches or the troop call sw, the 12/24v volt switch near the volt meter, the lamp test sw and all the gauges. CB77 is lower right on this drawing, CB77 output to dash circuits drawn upwards from that point.
i suspect you have a chaffed/shorted wire between the power panel and the main dash panel devices it powers.
i would pull the steering wheel to lift out the dash for a proper looksee… you can disconnect the buzzer, gauge and lamp test switches easy enough to eliminate those devices. You will probably have to unplug all of the gauges individually to isolate them
Good Luck.
AlaskanLMTV
Palmer, AK
Good Luck.
Thank you!! this is immensely helpful direction to chase, I was going down a much darker rabbit hole.
I suppose its never to late to tell you, I'm functionally electrically dumb. LOL!! But, I have a nice multimeter and I'm tenacious enough to learn this one way or another!!!!
Next challenge, I have family in town for next week and then I go back to work for a month. So, please please please stay tuned, when I get home and can play with this thing again, I promise I will update!
AlaskanLMTV
Palmer, AK
Good chilly afternoon from Alaska!
Back from my 3 week hitch in the arctic, playing with this thing in the driveway again.
We've pulled the steering wheel and looked at the wiring behind the dash, nothing looks terribly out of order. I pulled the connector J301 from the back of the PDP and it won't pop the CB77 fuse. Next, I pulled terminals from that connector one by one, and proceeded to pop another dozen fuses. there is only one terminal that I can't remove, has two wires: 1546-a and 1546-b.
then I slid back over to the driver seat and tried manually looking for the other end of those 2 wires, no luck. Now I'm paging through the EWD, trying to keep from going cross eyed. The termial is very solid in the connector, the PDP side kinda looks like it has been hot. And since its the only one I can't isolate, I'm kinda leaning toward something downstream of those two wires.
AlaskanLMTV
Palmer, AK
slight update!!
I got to the end of the wires that lead to the volt gauge. Disconnected the volt gauge and CB77 holds now. Everything on the dash (except the volt gauge) come to life and things are starting to click and buzz!! Still not getting a Start Signal... power on turns everything on, big red button doesn't do anything.
Here's to failing successfully!!
Ronmar
8,142
Port angeles wa
Do you get an oil pressure idiot light when you turn on the ign? K26 and K11 both must energize when you turn on the ign in order to enable the start pushbutton as K11 provides the power to the button when it is energized. K26 is controlled by the transmission neutral start signal. It provides power for K11. K11 is controlled by the 15PSI low oil pressure sw down on the engine block. That switch provides the path to ground for both K11 and the oil idiot light, so no idiot light no crank
once the engine starts, the 15PSI sw removes the ground path, which turns off the idiot light and de-energizes K11. this disables the starter and shifts that starter power to the alternator to bring it online…
AlaskanLMTV
Palmer, AK
Good May morning from Alaska! Finally getting somewhere with this thing, figured I'm way overdue for a followup.
With the dual voltage gauge removed from the dash, we have power through the PDP and all relays/fuses holding. Tested EVERY relay and resettable with multimeter, verified coil resistances and ohms on each resettable, the only way we can start this thing is with a remote solenoid trigger, but it starts!!! Fires right up, idles nice, shifts nice, good to finally start seeing things come back to life!
Next will be disassemble dash to track wires for the big red button and volt gauge, need to see why CB77 isn't happy with them hooked up.
Then, a little battery box customization, and we should be blazing down the road at 55mph!!
GeneralDisorder
5,985
Portland, OR
Hopefully it hits 62 mph (100 KPH is the magic target) like it's supposed to. That should be it's gear limit with the engine at redline. The A1 trucks usually have no issue hitting that due to their enhanced power and slightly higher redline.
Ronmar
8,142
Port angeles wa
When you turn on the ignition switch, k11 must energize, you should also see an oil pressure idiot light. If K11 energizes, it should provide 24V to TL162 on the start push button. When you push the button that 24V gets fed across to Tl163 on the other switch terminal, then down to TL33 on the aux start relay on the drivers frame near the starter. The other small terminal on the aux start relay, TL23 should have a path to chassis ground TL25 to complete the circuit.
AlaskanLMTV
Palmer, AK
Good afternoon from Alaska again!
We've made progress, even took this thing around the block. With no plates, registration or insurance.... was a quick dirty ride!
Still struggling with the K11 relay. 24v at the 85 terminal, tells me the K26 is seeing Neutral. If we manually jump K11 terminal 30 to 87, start button works perfectly. Then switch the jumper to 87A and the alternator comes online. Does K11 need to be a 24v relay?
Next observation, transmission feels like its slipping. if you ease into it, it will lock up and drives very much like I figured it would. Very um... positive shifts!! Running 15w40 in there, all new filters. Once you get moving, it shifts and runs good. Forward and reverse are positive engage. if you park and let it idle for a minute, it feels like it slips for a bit before it engages. Maybe just need to get more fluid circulated? Operating temps, dipstick shows full. Do these like to be a little over filled?
Haven't made any progress with the volt gauge yet. Still running with a hole in the dash....
Ronmar
8,142
Port angeles wa
The neutral relay K26 provides the 24v for K11’s coil on pin 86, but that is not what controls K11. The path from pin 85 to ground which will allow current to flow and energize the relay is how K11 is actually energized.
So once again I ask DO YOU HAVE A LOW OIL IDIOT LIGHT IN THE DASH WHEN Y0U TURN ON THE IGNITION SWITCH?
the 15PSI low oil switch on the drivers side of the engine provides a path to ground for both the idiot light and K11 when the oil pressure is below 15 PSI. As soon as you start the engine, and get >15 PSI, the switch opens, turning off the idiot light and de-energizing K11, K11 then shifts the start power from feeding the start circuit over to turn on the alternator(K11 must be a 5 pin relay) to start the alternator feeding the power system…
if you don’t have an oil pressure light, look to the oil pressure sw on the side of the engine… if the oil idiot light is OK and works normally(goes out shortly after engine start) then the issue lies in the wiring to K11 or K11 itself…
AlaskanLMTV
Palmer, AK
my apologies, I thought I had addressed all previous comments. Yes, we have a low oil light on the dash when power is turned on. I also installed a new low oil pressure switch because it was inexpensive and semi-easy to get to, just to rule out the K11 ground issue. But, you've hit on something!!
I'm still on-shift at my rotation work for another couple weeks, but I'm going to check continuity from the K11 to the connector at the low pressure switch and see if there is connections. Can't hurt to keep making myself familiar with the electrical architecture of this thing.
