- 300
- 231
- 43
- Myakka City, FL
I'm once again turn to the folks that have worked on these critters. I have a PTO winch that will not work. The problem is electrical. All the switches are good, good power source, and the PTO is engaging and the light on the panel shows it. The problem I am having is finding the connectors to check power going to the solenoids. The IN and OUT switch is working. Now I may be looking at the connector on top of the solenoid but I don't want to pry so hard I break it and I would rather not pierce the wire if I don't have to.
All help is appreciated.
Thank you , Lugnuts
Thank you , Lugnuts
