roberbert101
- 0
- 1
- Bolivar, Mo
So the worst thing ever happened. The nose cone for the starter broke and the starter dropped ripping the ends off most of the wires including some of the larger wires as gravity took course and i found the starter dancing with the front driveshaft and leaf spring. I have since replaced all of the ends, but need to know which wire goes where. I have identified the momentary start wire and returned it to the starter. The main question is what large wire goes where? I have it currently one large 24v wire to the solenoid feed side. and then on the starter motor stud there is a ground strap to frame and then a second -24V wire... both large diameter... they are connected to the starter motor stud, But it will not crank. The solenoid clunks but no whirl. The rest of the circuitry looks to be right. no magic smoke has been released.
Is their a simple diagram somewhere? The starter and solenoid currently installed is brand new. please help, something doesn't add up...
