M1078 starting
cheesehead dave
crivitz, wi
Engine would not crank. Suspect neutral safety switch. Don't know where it's at. Bypassed by running a push button switch to the remote start solenoid. Works great, but would like to do it the right way. Where is the neutral switch located? Thanks.
dmetalmiki
2,028
London England
Usually a top the the gearbox somewhere, however, It's on the LEFT SIDE, (facing forwards) halfway up going into a 'shelf on the side. just follow the electrical wiring down to it. (the plug)
NDT
6,486
Camp Wood/LC, TX
It's a relay inside the VIM under the PDP. My suggestion is to follow the comprehensive troubleshooting guide in the Technical Manual. Could be quite a few other components as well.
Suprman
696
Stratford/Connecticut
Could be something as simple as a bad start relay in the panel. There are 2 fuses in the vim although I have never seen one blown.
coachgeo
3,460
North of Cincy OH
Much Much thanx Will. Folk like you really help all of us learn just a little more about these trucks every day.
So with your info went into bit more search that seems to say VIM is Allison Module for tranny. Onward into deeper search and tadaaa...
VIM = Vehicle Interface Module.
This brought up what think is posted here already but just in case if not...... here is a troubleshoot guide for Wtech II and Wtech III shift pad/ECU/VIM
http://www.transmissioninstruments.com/troubleshooting.html
Sorry to the OP for the Hijack........ now back to starting issues.
