Thanks.All the trucks use the same radiator: 2930-01-519-3573
All the FMTV's use the same radiator. A0, A1, A1R - heck I think the A1P2 is the same also.Actually need for an A1. Or is there a separate A1 series of TMs?
Oh you mean TM's. Private message me. Those aren't public domain and they aren't simple documents. The A1+ trucks require the military digital reader software and have a high level of diagnostic integration. Totally different.Actually need for an A1. Or is there a separate A1 series of TMs?
If you have A1's you MUST have a laptop with diagnostic software or a J1939/J1708 scan tool. Without being able to look at computer I/O you can be left with ZERO ability to diagnose a problem. A good example is the boost pressure transducer - that can get "stuck" at 0 psi (it's normal state when engine is off) and the ECM has no way to detect that fault - it breaks the fuel system feedback loop and the ECM does not provide enrichment (can't see the turbo spooling) so it never provides enough fuel to go more than about 10 mph. NEVER gives you a check engine light even. And you will NEVER figure out the failure without being able to see live data and take note that boost pressure remains at zero when the turbo is clearly making some pressure. You are essentially blind and deaf without a diagnostic interface so the young guys have a point - you should ALWAYS consult the computer (the gatekeeper) before you perform any other diagnostics. They probably just aren't experienced enough to have alternate diagnostic methods under their belt yet.FD has a couple young Freightliner/John Deere mechanics that apparently know some stuff but pretty much dependent pluggomg in a laptop. Anything more than ___ yrs old is a mystery.
