SailBoat
- 12
- 3
- Darlington SC
The CTIS is constantly pumping air to the front passenger tire, then when it gets to where it needs to be it’ll start exhausting out of the quick release valve. Then goes back to pumping air to the tire and repeats.
Thought it was the quick release valve so I changed it out with a new. Didn’t solve the problem.
Loosen the banjo bolt and can hear air coming out when it starts exhausting. But when I do it, it drops enough to close the wheel valve I believe and stops. So changed the wheel valve out 3 times and still have the same problem.
changed the tire to see if that would do anything to no avail.
undid the hub full plug to see if I could hear air coming out and it’s not. Also plugged the stud where the wheel valve hooks to and my hwy light stays solid and acts fine.
Could really use the help been on this problem of the truck for about two days now
