M1079 AC Cable to Genset
fjdedrick
Toledo
I swear I looked every where... I am looking for an AC 110/208 VOLT cable with connector to go into the M1079 Box. I cannot find a part number or one for sale anywhere!
Sent from my VS995 using Tapatalk
155mm
Chief and Indian
388
Guymon, OK
What is the amp rating? 200 amp is just a little bigger than 100 amp. I have something that will connect, but need to know what size.
Edit. 200 amp connector is larger than the 100
fjdedrick
Toledo
I'm going to say 200... I'll take pic of the box of that helps
Suprman
696
Stratford/Connecticut
Replace it with a civilian twist lock. Convert to 120 240 single phase. Unless you specifically need 3 phase for something. The military cabling is expensive and overkill for most people.
fjdedrick
Toledo
I think that's where I am heading... Actually converting this into a coffee truck and am trying like **** to get a Genset Trailer.. Was hoping for a matching cable.. But looks like I may need to rewire.
155mm
Chief and Indian
388
Guymon, OK
By the dimensions, its 100amp. If you clean the data plates up that are right below the connectors, it will tell you what they are. Should look something like this.
I have 2 female to fit that
I dont have an loose male plugs.
The male plugs I have are on an extension cord that cost me a pretty penny, but not as much as the one listed earlier.
fjdedrick
Toledo
I'm going to go remove the paint.... How much for the cable.... God I hate to cut it... I only need that female...
155mm
Chief and Indian
388
Guymon, OK
I would pull the one out of the dist. box and cap the hole before I sold the cable knowing it was going to get cut. Yes I know if I sold it, it is none of my business what he does with it, but go find another one and see how long that takes without paying an arm and leg.
