M1081A1 won’t shut off
Rican
JBER Anchorage, Alaska
The truck will turn on fine but the only way to turn it off is by pulling out the xmsn ecu cat ecm circuit breaker.. also while running the panel is Christmas lighting.. any solutions on this problem.. will be very much appreciated
NDT
7,436
Camp Wood/LC, TX
You are saying when you turn off the ignition switch, absolutely nothing happens? Did someone flip some of the switches under the cab? What specifically does “panel is Christmas lighting” mean? Flashing on and off? Every idiot light lit?
fuzzytoaster
3,711
Fort Worth, Texas
Hmm.. M1081A1.. with a C7 engine? The "Christmas lighting" sounds like the weird power issue that the later A1R trucks have that people commonly call the "disco lights".
Rican
Well the Christmas lighting is most likely an alternator issue, but still can’t figure out why the truck won’t power off and none of the switches are up from under he cab.. and yes I am saying that absolutely nothing happens when I flip the ignition switch or even disconnect the battery
Rican
I would start by unplugging the under cab switch panel to eliminate it from being a cause. I think that can be done.
well I just ended up disconnecting the ECU and connecting it back and it worked again. Thanks for the replies
