aleigh
- 52
- 48
- Phoenix, AZ & Seattle, WA
Haha that's priceless. It did fine down to PHX obviously, couldn't even tell it was there. Just wondering what their logic was. Then again there is no way these things "only" hold 2 1/2 tons on highway...The one you have did just fine loaded at hwy speed across TX and NM....
I don't quite follow. If by laws of physics you mean the gears, because I am pretty sure the guys with the FMTV hwy gears would say it's quite possible to tow one at interstate speeds with a M/V. Are you suggesting the manual is right and there is some reason not to, if you otherwise could?I am going to drag my M1082 home tomorrow for the last leg of a recovery from Ft Bragg that started its journey back in March of this year. Thanks Wes for towing her to Newberry Florida & Sandcobra for storing her for so many,many months. Max speed, probably 45-50 mph as the Deuce tows, just as long as she gets home finally. Would I tow her @ interstate speeds, no. The laws of physics prevents it with a Deuce or the LMTV fortunately.
Tires?on the topic of hwy speeds in an LMTV. Hi speed gears is the best thing you can do for your truck. They ARE engineered for "high speed". Sorry but that claim is completely unfounded. The idea that an LMTV or its matching trailer wont handle 80mph is not backed by any amount of fact. Every part in these chassis are used in the civilian world on commercial hwy trucks every day.
As someone who actually does travel at 75mph in my MTV, I can say definitively the truck is far happier turning low rpms than high rpms. But there will always be the "experts".
Goodyears are rated at 85mph....Tires?
81. They are also rated at 9370lbs at 95psi which your wheels aren't rated for.Goodyears are rated at 85mph....
Not sure what you are getting at. Are you meaning to say that a tire rated for 9370lbs and 81mph, is not working within its perimeters when loaded at 5000lbs (or less), set at 55psi, and spinning at 75mph?81. They are also rated at 9370lbs at 95psi which your wheels aren't rated for.
Sent from my SM-G935P using Tapatalk
Highway rating is 95psi for 81mph.Not sure what you are getting at. Are you meaning to say that a tire rated for 9370lbs and 81mph, is not working within its perimeters when loaded at 5000lbs (or less), set at 55psi, and spinning at 75mph?
Or are you just splitting hairs?
