M1082 omnivolt LED light numbers
Slate
378
Ozona Texas
I have an m1082 and it seems the lights work but are plugged in wrong anyone got a diagram as to which number or color goes to which number on trailer wireing? Thanks in advance.
Sent from my moto z3 using Tapatalk
flyfishtrailer
1,015
Cool, CA
I have never owned a 1082 trailer, but just about all of them are going to be the same as the military keeps it simple. Try this one from an M100...it may be what you need, or enough to get your wires in order
Slate
378
Ozona Texas
The problem is on these lmtv trailers the numbers are j259, j260,j261, j258 and a ground of course. They don't match up with anything. Unless I try to substitute the 2 for a 4 but that would only work for one. And the lights seem to work with different numbers off and on so it doesn't make a lot of sense. Sometimes they want to work and other times no.
simp5782
Feo, Fuerte y Formal
9,327
Mason, TN
Trucklite/Grote LED lights: white-ground, red 21-tailight, blue 460/461- turn signal and brake,
yellow 23- blackout drive, green 24-blackout marker.
Stewart Stevenson: J258-right taillight, J262-left taillight, J259-right turn, J263-left turn, J264-blackout marker left side,
J265-blackout drive right side, J260-blackout marker right side, J261-blackout drive right side.
flyfishtrailer
1,015
Cool, CA
Okay....I will look some more...that weird though as even the vehicles typically use the same numbers for service tail lights, blackout lights, etc. I'll respond if I find something
Slate
378
Ozona Texas
Simp got it. That's what I was looking for. That y I was confused.I thought numbers were all the same as well.
