M1083 5 ton Front Brakes and Information Needed/
Lugnuts
236
Myakka City, FL
I am in need of parts for my front left Meritor Wedge brake. I did manage to remove the guts from the wheel cylinder. I do have kits. But my Brake chamber and wedge are not per se salvageable. The Chamber and tube I could probably reuse if I had to but the Wedge and Spring and the rod that runs up to the chamber are pretty much toast. I have combed the internet and not found the long versions of these. Any replies greatly appreciated.
Also I have a parts book for a M1078 but different than the 5 Ton. Where might I be able to obtain a (e)catalog for the beauty. Appreciate all the help people have given me in the past. Thank you
simp5782
Feo, Fuerte y Formal
9,369
Mason, TN
1083 manual lists the front as the same service brake setup as the 1078. Its a service brake. Not a spring brake on the front. There are a few on Ebay
Its called a wedge not a wheel cylinder.
Any air brake parts can be found in the euclid catalog. Including the stems. Just need to know what diaphragm you have
Just Google search euclid air brake catalog
Front drivers brake on a 1083 pictured below
There also should not be a spring in that tube. Only on the wedge itself.
Common wedge kits as well
simp5782
9,369
Mason, TN
For the pushrod
simp5782
9,369
Mason, TN
All of it is common thru any truck parts place local to you. Or found online. LMTVs use the same brake system parts that have been used for years.
You would have to measure the rod to get the correct one. The tubes with the service cap are on Ebay for reasonable prices
Lugnuts
236
Myakka City, FL
Thank you. I saw the one on eBay
coachgeo
3,461
North of Cincy OH
TM's for the MTV are also available for free online for the A0's.
What Wes (Simp) says. 👆
The brake parts are pretty generic commercial truck. Try FinditParts.com seem to recall reading that the long stem brake chamber is available they just show a generic brake chamber picture with short stem so if you don't read close you will skim right past the listing on a truck supply page.
Lugnuts
236
Myakka City, FL
Thank you
