M1083 CTIS Solid lights trip 24volt breaker
tcarr1083
Hampton Roads, VA
My 1083 has 223 miles on it. The CTIS lights stay on until the 24V breaker trips. I have swapped relays, breakers, the ECU itself. Unlplugged all of the pressure relays under the truck and it does the same thing. Inspected the wire harness best i could from under the cab and under the fuse box and there is nothing out of order....
Any thoughts?
