Ultra Mag
- 17
- 8
- Culpeper VA
rolled cab over today to fix water pump. started it up to see if it leaks water. Right away it started dumping air , ctis HWY light flashing. help please thanks.
Dumping air from where exactly? If it is CTIS, the dump and wheel valves are controlled by air pressure. It takes a certain amount to open the wheel valves(6-7 PSI). The dump valve is basically a remote pressure regulator. When you decrease pressure on the supply side of the valve the valve dumps tire side pressure to match. So a leak or valve issue around the PCU could cause ALL the dump valves to activate. So where is it dumping air from.
The best way to troubleshoot CTIS is to connect shop air to the emergency gladhand in front so you can look for leaks without the engine running. Chock the wheels as applying air there also releases the park brake...
If it is the controller causing it, simply unplugging the controller should stop the dumping.
That would be weird... the quick release valves are controlled by air pressure(basically remote controlled regulators) and they should all see the same air pressure coming from the PCU. The dump valve in the PCU connects the manifold to a 7PSI relief valve on the side of the manifold and is normally closed. You can see this relief on the PCU near the pressure sensor. The dump valve sends air to that relief which acts like a regulator to lower the manifold pressure to around 7-8 PSI(Just enough to keep the wheel valves open).I had a 939 that was only dumping rear because of pcu dump valve
