M1084 Highway gears
ERT007
Florida
I am purchasing a M1084 and really need to make it more interstate friendly before I even start the conversation. Any input on the proper way to do this? I have heard of just changing the transfer box gears. I would hate to have to change out all axle gears but I have to do what is best for safety and life of the truck>
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
Tires is the simplest.
395s to 1400s will give you 6 to 8mph top speed increase so around 65mph. 1600s will give you a top speed around 71/72.
Continental HCS is available in 1400R20 but aren't cheap. Most of the 1400 stock has dried up from military surplus that aren't 10yrs old.
1600s are found in goodyear AT3s and Michelin XZL are around 400 new for 2017 date codes and newer.
Otherwise you have to swap gears in all 3 axles. Rear axles are simple and done in under an hour per one. Front takes a few hours.
If you have a A1 or A1R1 truck the gears are worth it cause you have the power to go. 3116 trucks not soo much.
ERT007
Florida
Thanks for the information. I am fortunate enough to have a nephew that is a CAT mechanic so I am going to see what it will take to change the gears. I will also look into the tires.
simp5782
9,329
Mason, TN
Gears aren't hard to replace especially the rears, it is acquiring them for the 4k or more for a pair. And you need a 3rd. So... factor in that 6k before the work is even started.
