M1084A0 Crane - Wire Rope Specifications
firefinder
10
Macon,MO
Anyone have specifications for the wire rope used on the M1084 Crane?
Found the Grove Part Number 6-246-100130 and NSN 4010-01-480-2479 in the tech manuals. Neither Grove or the NSN resources list the specifications for this item. Unable to locate a specified length either.
Thanks!
firefinder
DiverDarrell
24
Port orchard, WA
What's the working load limit for the crane, use wire that matches. Unless it's a grooved drum. Then depending on what side the wire attaches to and drum rotation depends on if you require right lay or left lay wire rope.
