M1088, Previous Runner, now no power at all... ideas?
ke6rwj
creating havoc one broken bolt at a time...
277
146
Alabama
yes, i have the manuals, yes im going through the flow charts etc... but nothing like experience...
The truck was driving fine, we drove it home from the Auction... it had air brake issues, and i had to replace a rear inversion valve, air dryer and the Governor/unloader on the air compressor... manual cab tilt pump reservoir was low, needed to fill to tilt the cab.. it hasn't been running in over a month waiting for parts...
after all that it wouldn't even power up...
- the batteries are known good.
- the battery hookup is correct and the same as before when it ran, and i double checked
- i serviced the battery connections, and they are all clean and tight
- i checked voltage inside the passenger side circuit breaker box 12 and 24v and there is voltage there
- all the breakers "seem" ok (not popped)
- master power switch on dash does nothing, no lights no power, and no draw an an ammeter
anyone have any ideas on this one?
Chris
glcaines
2,588
Hiawassee, Georgia
How do you know the batteries are good? I would recommend charging the batteries. If you don't have a 24 VDC charger, use a 12 VDC charger and charge each battery separately. I had a 6TL battery in one of my deuces fail unexpectedly. Headlights worked. Starter wouldn't turn over. I discovered the bad battery by using jumper cables to my car separately for each battery in the deuce. Jumping the second battery with the cables, the deuce started right up.
ke6rwj
277
146
Alabama
Each battery was disconnected and removed for service. I used a digital and analog battery load tester and they all passed. fine...additionally i have a large Schumacher boost box in 24 v ( i use it to start multiple large MCI tour busses without issues) and tried with that and it had no affect.
I could imagine that if the batteries were "low" i would get at least dash lights... i get absolutely nothing in the dash...
unless there is a hidden shut off switch somewhere, i guess going through each breaker and testing them is next...
Chris
Ronmar
7,403
Port angeles wa
Voltage check at power panel test points = good. Not testing While under load = bad... gotta test when loaded(switch turned on) or they don’t count.
what year truck?
when you turn on the Main switch, it energizes the instrunment power relay K2 In the PDP. I would start there. 12v flows from the test point in the PDP, thru CB70 To the Main switch, back to K2’s coil(pin86) and pin 85 connects to Terminal board 2(tb2 = ground) to complete the circuit that powers rely K2...
Ronmar
7,403
Port angeles wa
Oh, and the breakers seem a little fragile to me. I kept a few for testing/troubleshooting, but replaced them all with standard automotive blade fuses. Way more predictable, especially when you add in vibration...
Skyhawk13205
263
Alaska
That is an interesting idea what is the max voltage rating for the ones you installed. It would be easier to see a blown fuse than Trying to figure out if the CB is bad
codematic
long beach, ca
for some reason my phone had me.logged in on this account... was an old one.. sorry for any confusion...
yea i did test voltages while attempting to turn on and off truck lights etc.. absolutley nothing.. and the voltage stayed the same, never moved.. makes me think there isnt any load at all.
what year truck?
1997
perfect! ill start with that in the AM
thanks...
Ronmar
7,403
Port angeles wa
1997
thanks...
Well if you cannot turn on the lights, start with CB70. In addition to feeding power to the main switch to power the K2 relay, it also feeds power to the lightswitch....
standard 12v automotive fuses will be fine For both the 12 and 24v circuits...
ke6rwj
277
146
Alabama
you called it, k2 was bad.. replaced it and it started..
thanks..
chris
ke6rwj
277
146
Alabama
im not a fan of these breakers i must say.. i think im gonna go old school...
thanks again...now on to the next problem.. ;-) i several military vehicles and it seems you really never get them all "fixed", you just move oo to the next issue..
chris
