M1088A1 -middle axle air solenoid piston air supply line snapped
jpfever
-1
Hagerstown, MD
So, over the weekend while attempting to remove the 5th wheel off of my 1088A1, I snapped the hard plastic air supply line to the air solenoid piston on the back of the power diverter. Has this happened to any of you? What actions did you take to either repair/replace the hard line or go with a more flexible line? Part numbers if possible. Any help is greatly appreciated.
Suprman
696
Stratford/Connecticut
Its generic air line you can get it at napa. Just take a piece with you. You will need the little brass bushings when you go to install the new piece.
