M1088A1 Voltage regulator
coachgeo
3,461
North of Cincy OH
Why do you think it is bad? Suprman in here has warned many times that the alternator will not work if it is NOT getting voltage from Battery. Very opposite of typical alternator. Do an Advances Search of this forum for "Alternator wire " by user "Suprman" and read some of this post on this topic then reassess if you need a regulator
DiverDarrell
24
Port orchard, WA
Read the many alternator post on here. Tons of good info, too much to re type. Just google FMTV and alternator, and look at the steelsoldiers links. May not the the regulator.
xomegaiv
Yuma, AZ
Ok so looking at the N2003 the LED light is off and the Charging System light in the dash panel is on. Looking at the diagnostics that means that my alternator is not charging. Is my alternator shot?
