M1090 Relay Valve and Brake Chamber part numbers
crownfire
Virginia
I need a part number for a new relay valve that sits on the inboard side of the left frame rail just opposite of the air dryer. A rebuild kit part number would be helpful too. Mine is venting air out the bottom. I've used the part number from the 24P but it looks like Haldex either doesn't make them anymore or they're they're back ordered from the factory. Hoping a brake chamber diaphragm isn't busted. I could also use a part number for front and rear brake chambers from a supplier that still makes them. Thanks
coachgeo
3,546
North of Cincy OH
Looks you got the TM's judging by your 24p mention. The chambers are pretty much commercial truck parts. There is also a quick and dirty spreadsheet stuck to the top of this FMTV forum with an ever updating list of part #'s
crownfire
Virginia
Yes, I would think it would be easy to find a part number that’s still in production but I can’t. Meritor says that since it’s a military part they can’t give me any specs. Axletech says they discontinued it so long ago they don’t have any specs on it. Just thought somebody has had to replace one before and was able to find a civilian version that works.
coachgeo
3,546
North of Cincy OH
must have missed my last post... will try again.... see sticky [h=3]Sticky: LMTV/FMTV Quck Parts Reference Spreadsheet[/h]
You will find it stuck to the top of this (FMTV) forum.
Just checked.... Yup, the front and rear chamber part numbers are in the spreadsheet...... with part number from sheet found one of them online without much problem.
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Give me the NSN or part number you are looking for. I will find you the commercial replacement.
