M1097A2 Brake Pads/Shoes?
Rybak97
Crawfordville/Florida
I'm in the process of changing out all brake pads/shoes and rotors on my M1097A2...... while doing everything else (geared hub seals, ball joint rubber, bushings, tie rod rubber, etc....)
I asked a local diesel mechanic to order me a set of brake shoes for the truck through O'Reilly's and the weren't right, see picture. They were shorter and had no chamfer on the edges for wear in. In the pic attached the old ones are on the top.
I did some digging in the Parts TM and found a kit p/n RCSK17215 and when I found them on Eastern they were $200 for 4 shoes. That listing had a link to a single shoe, NSN 2530-01-253-2825, for $13.99 per shoe. What is going on?!? The single shoes on their site look short like the ones at O'Reilly's but $200 for the kit of 4 seems steep. I want the proper shoes and will pay $400 if I have to but dang!
Am I missing something? The TM's do call out 4 for the fronts and 4 for the backs, are they different? I just want a full set of pads, can someone open my eyes to whatever im struggling with?
Rybak97
Brake pad and brake shoes are two different things. Last time I checked, Humvees do not have drum brakes.
Eastern’s prices are always ridiculous.
Parts TM calls them "disk brake shoes" so that's what I call them. I'm aware that my truck doesnt have drums. Thanks for the help.
Sent from my SM-G955U using Tapatalk
86humv
496
Texas
If you have 12" vented rotors...I have nos surplus pads........2530-01-420-8025
springer1981
1,148
Maine
If the ones in your picture fit I see no reason you can't use those. The pad design is slightly different but overall they look like would fit from what I can see.
